which is the best and most efficient way to generate saw tooth waveform? I mean by:
i- 555 timer
ii- 8038 ic
iii- Micro controller
or any other?
i- 555 timer
ii- 8038 ic
or any other?
The 555 will do it, but the threshold points are 1/3 and 2/3 of Vcc. You'll probably need amplification and level shifting.which is the best and most efficient way to generate saw tooth waveform? I mean by:
i- 555 timer
ii- 8038 ic
or any other?
Last time I checked they are still available on ebay.The 8038 does not need that, but it's obsolete so i had to recommend this. I hated to see these parts becomes obsolete.
Hi,Last time I checked they are still available on ebay.
Those I bought a year ago work just like they should however they don't look like NOS(real cheap too) so most likely someone is copying the chip using the Intersil name...
One model is still available as "current" on Digikey. At an extreme price.Hi,
Yeah i wonder where they are coming from. Maybe extreme overstock.
I made a typo in my last post too, i meant to say that i find it hard to recommend the 8038 because it is obsolete. But if you can find one and you are happy with it then all is well.
These (crystal oscillators) are nice, maybe even 'best' by criteria other than cost.which is the best and most efficient way to generate saw tooth waveform? I mean by:
i- 555 timer
ii- 8038 ic
or any other?
i- 555 timer
ii- 8038 ic
or any other?
Hi,One model is still available as "current" on Digikey. At an extreme price.
https://www.digikey.com/product-det...uctor-corp/CMPP6028-TR/CMPP6028-CT-ND/5324497
I bought a box full of stuff from a closing TV repair shop. There were three in a carefully marked envelope in that box. I have them in my junk box but never found a use for them.Hi,
Wow what a price. Nice to see them still around though.
I only used one in my career. Only saw maybe three in use elsewhere.
Hi,I bought a box full of stuff from a closing TV repair shop. There were three in a carefully marked envelope in that box. I have them in my junk box but never found a use for them.
I've really only seen them used in designs for intro Electronics books (they show up in nearly every one from the 1970s to mid-2000). Also Forest MIMS workbooks.Hi,
Yeah ha ha, and i was always sort of afraid to use them in a new design because i had viewed them as esoteric and almost a novelty rather than a steadfast part that i could be sure could always be obtained. That and the fact that i dont think their specs were as good as i would have wanted anyway compared to some other design doing the same thing. If it is hard to ensure something will work over a certain range of changes i dont like to use it unless it is the only possible way to do it.
