I have new drivers installed.
I'll pull and test them. (and match)Have extra.
It may be, the mismatched finals killed the drivers again. They really suck, beta wise. As do the good side ones.
Need a new battery for my beta tester. Hasn't seen the light of day for 10 years.
If driver died, this may be my final (pun) attempt.
This is really just silly! Friend said not to bother with difficult repair.
I'm just embarrassed, as it should have been simple!
Same problem.
Took out 802 with difficulty. I'm losing patience.
Checked great. Much better than other. 756s.
Put it back, and everything is fine again.
I must have another 756 somewhere, that was removed. Or another new replacement.
Next failure I'll go right there. (802)
This may go down as one of my more frustrating repairs.
Worked perfectly all day yesterday. Hot and cold spray.
New finals and drivers.
Tried new tx in the next stage back when not working. They tested fine so I put in originals.
Then I removed TR802 which tested fine.
Put it back and things worked fine all day.
Plugged in this am and I'm back to high standby current through finals.
Thanks to earlier suggestion, I have a more or less permanent 60 ohms in series, and monitor V drop continually.
I will now cool and heat TR802, and replace it either way. This is about my last chance at success.
I've been busy with other things. Don't have the will right now to make a step by step comparison to good side. It's shotgun or "the shotgun.
Aha, heat brought it back.
Not in the TR802 area though. Unless I wasn't patient enough. I move quite quickly to another error.
Now it should be just a matter of time to find the right resistor/part.
It may take a day between tests though.
