Has anybody here used this company's products to any degree?
How do they rate in terms of what you get for what you pay?
I've used the $10 8-Channel 24 MHz clones with https://sigrok.org/wiki/PulseViewHas anybody here used this company's products to any degree?
Why is that described as a "clone" when it runs at only 24 MHz but the thing its cloned from runs at at least 100 MHz? Also if it is a clone surely it can work with the same Saleae software?I've used the $10 8-Channel 24 MHz clones with https://sigrok.org/wiki/PulseView
https://sigrok.org/wiki/MCU123_Saleae_Logic_clone
Cloning is never perfect when the objective is being cheap. Yes, the original clones would run on Saleae software because that's the value of there products but now there is open-source for the clones that is very good.Why is that described as a "clone" when it runs at only 24 MHz but the thing its cloned from runs at at least 100 MHz? Also if it is a clone surely it can work with the same Saleae software?
Man these clones must be killing Saleae, what a huge problem for them, if I was CEO I'd make that one of the top priority goals for the year to stamp out these clones.Cloning is never perfect when the objective is being cheap. Yes, the original clones would run on Saleae software because that's the value of there products but now there is open-source for the clones that is very good.
https://atadiat.com/en/e-hands-on-test-saleae-usb-logic-analyzer-24mhz-8ch-clone/
The Chinese cloners are shaking in their boots.Man these clones must be killing Saleae, what a huge problem for them, if I was CEO I'd make that one of the top priority goals for the year to stamp out these clones.
They very well might be if Saleae reduced their own hardware costs substantially and began charging for their (very respected) software on a subscription basis. It seems to me that the software is a far more valuable IP asset than their hardware.The Chinese cloners are shaking in their boots.
Exactly, their hardware is made overseas like most products.They very well might be if Saleae reduced their own hardware costs substantially and began charging for their (very respected) software on a subscription basis. It seems to me that the software is a far more valuable IP asset than their hardware.
Not as yet as it's a fairly complex PCB inside them with its own microprocessor however there are hacks for the licensing SW for them.I wonder, is there a clone for this Siglent part?
So I wonder if getting this makes sense for me because I have the 4-chan 200 MHz version of the scope already.I found out that Kingst Logic Analysers have a reasonable bang for the buck - I have a LA2016 (midrange) that I got for about US$70~80 in one of their new years or black Friday promotions. It is quite well built and has great software.
As a hobby user, unfortunately I can't justify the cost of a Saleae Logic Analyzer. At work we have tons of them and they work well, but they can afford them.
I have a older Tek MOS with 16 digital inputs. It's a nice addition to have the analog and digital synchronized on the screen. You really need a large screen for data display.So I wonder if getting this makes sense for me because I have the 4-chan 200 MHz version of the scope already.
It may make sense, but usually a PC-based solution can be more expandable and, as @nsaspook mentioned, a large screen is an extra benefit. I think your oscilloscope has a VGA output, thus it may compensate in this aspect.So I wonder if getting this makes sense for me because I have the 4-chan 200 MHz version of the scope already.
L | Control logic for Mosfet | Power Electronics | 5 | |
L | Question about a control logic needed to be implemented | Homework Help | 15 | |
Cheap USB Logic Analyzer (Saleae clone) | Test & Measurement | 1 | ||
M | Saleae Logic Analyzer Clones | Test & Measurement | 6 | |
Saleae Logic - logic analyzer | Microcontrollers | 0 |
