safety of desired configuration
shay7
Joined May 11, 2019
If I have an 800KV 12KW motor, rated at max 60V, 200A, and i supply power to this motor using (say) 45V li-po batteries through an ESC (ideally rated higher than 200A), what effect will this have on my configuration? Will the battery be safe and will the motor pull a higher amperage in order to produce the same power, thus frying the motor and ESC?
mvas
Joined Jun 19, 2017
539
Is your 200 Amp ESC, current limited to 200 amps ?
If true then no the motor will not "... pull higher amps in order to produce the same power ..."
The motor will consume less power at 45 Volts vs 60 Volts
12,000 Watts = 60 Volts x 200 Amps
9,000 Watts = 45 Volts x 200 Amps ( or less* )
* The 45 Volt battery pack may not be able to push 200 Amps into the motor
KeithWalker
Joined Jul 10, 2017
3,628
It depends on the load you are using.
If, under load, when connected to 60V, the motor is drawing close to its maximum of 200A, connecting it to 45V, using the same load will cause it to draw more current and exceed its ratings.
If, under load, the motor is drawing much less than maximum current, It may be possible to change the load (prop diameter or pitch) to work with a lower supply voltage at higher current without exceeding the limits, to supply the same power. To do that you will need the detailed characteristics of the motor and of different props to match them correctly.
