AlbertHall
- Joined Jun 4, 2014
- 12,653
Read post #9.So, it the noise that starts the oscillations. Thanks Dana. So, the amplitude at the ends of the crystal differ?
Why would you expect the signal on the two crystal pins to be the same?
I would expect the output pin to be larger amplitude and not a good sine wave.
The input pin gets the signal from the output pin as filtered by the crystal so I would expect a lower amplitude but a better sine wave.
All of this will be affected by connecting a 'scope probe so waht you see on the 'scope does not exactly reflect reality.
