RS485 hardware connection issues.
John P
Joined Oct 14, 2008
2,068
The MAX485 (now made by Analog Devices, and others) is the interface component you most often hear about, though there are other pin-compatible components from other manufacturers, and the old SN75176 (pre-CMOS) was the same. On the MAX485, A > B is treated as a 1, A < B is a 0. Another way to think about it is "When the output is active, A matches the input pin, B is the inverse of the input". That's the most common convention. And of course for the receive direction, "The received data matches A, and is inverted relative to B".
Picbuster
Joined Dec 2, 2013
1,062
I have a problem with a hardware board where i do not receive the uart data but the board can transmit. The transceiver is SN65HVD08D, i have given 3.3V as supply to the transceiver, but the micro controller is 5V so the DE, UART Rx and Tx are all 5V from the microcontroller. i am testing using USB to RS485 converter connected to the PC. USB to RS485 Converter Module - leetechbd
when MPU output is 5V and the line driver =3v3.
The linedriver will clamp and could go defective.
Solution resistor (10K approx) connected between transmit pin in mpu and input line driver.
Place a fast diode between 3v3 and the input of the line driver.
the voltage on the line driver will be 3.3V-diode voltage.
Current in that circuit during MPU high (5-(3.3-.6)/10K = 0.23 mA approx so no risk.
.6 = voltage over diode in conducting state. check data sheet for zener used
line driver: rs485 chip.
input line driver: from mpu.
Remark: some use zener diode. However a zener is not fast and need more current.
Picbuster
