RS485 & Arduino
Hedalen
Joined Dec 5, 2010
22
Is here someone, who can advice me how to make a RS485 network at home, with Arduino prints and MAX485
i shall be 1 master and 7 slaves
strantor
Joined Oct 3, 2010
6,875
There are several RS485 shields for arduino and many of them are open source with schematics available for download. You can buy the shields pre-made or you can rip off the design and roll your own. No need to design from scratch.
The network is simple. Put all the devices in parallel with a trunk cable with a 120 ohm resistor at each end. Cable should shielded twisted pair.
Papabravo
Joined Feb 24, 2006
22,116
There is a basic choice you need to make early in the design process. Should the bus be a 2-wire bus or a 4-wire bus. With a 2- wire bus you will be limited to half-duplex communication. That is you cannot transmit and receive from a node at the same time. At ALL time a node is either transmitting or receiving, but NEVER both at the same time. With a 4-wire bus you can achieve full-duplex communication meaning you can transmit and receive at the same time
