RS232 TTL = UART??
mcgyvr
Joined Oct 15, 2009
5,394
Looking at a 2D barcode scanner to incorporate in a Arduino new project..
Description from Honeywell says its RS232 TTL... (they have 2 cables.. "true rs232" and "rs232 TTL")
Would RS232 TTL be the same as UART?
djsfantasi
Joined Apr 11, 2010
9,237
As far as an Arduino is concerned, the answer is yes.
From the Arduino page:
"Used for communication between the Arduino board and a computer or other devices. All Arduino boards have at least one serial port (also known as a UART or USART): Serial. It communicates on digital pins 0 (RX) and 1 (TX) as well as with the computer via USB. Thus, if you use these functions, you cannot also use pins 0 and 1 for digital input or output."
...and:
"to use them to communicate with an external TTL serial device, connect the TX pin to your device's RX pin, the RX to your device's TX pin, and the ground of your [Arduino] to your device's ground. (Don't connect these pins directly to an RS232 serial port; they operate at +/- 12V and can damage your Arduino board.)"
mcgyvr
Joined Oct 15, 2009
5,394
It just threw me that they call it RS232 TTL...
Why leave the RS232 part in there?
You don't think its something like -5/+5 for high low?
mcgyvr
Joined Oct 15, 2009
5,394
Thanks Guys...
I'm gonna just treat it as RS232TTL = "arduino approved serial" and move on without needing any additional circuitry..
35,245
Sometimes folks confuscate RS-232 with TTL and UART.
A UART chip sends and receives NRZ data at TTL voltage levels, 0-5V. The idle voltage level (MARK) is 5V (logic 1). The first bit transmitted is the START bit and is a 0V (logic 0) or (SPACE).
RS-232 is a voltage standard. Various voltage schemes have appeared in practical usage such as ±3, ±5, ±10, ±12 and ±15V.
To convert from RS-232 voltages to TTL voltages and vice-versa you need an RS-232 receiver-transmitter chip.
These converter chips usually perform a logic inversion.
Hence idle voltage (MARK) is -15V (for ±15V system) and the START bit is +15V (SPACE).
So in a nutshell:
UART is a serial communications hardware and protocol
TTL is logic represented by 0-5V voltage levels
RS-232 is logic represented by -15V to +15V voltage levels or similar voltages.
Edit: I got distracted while typing this. Gopher has nice pictures to illustrate this.
djsfantasi
Joined Apr 11, 2010
9,237
Mr. chips has it right. Arduino and others have confused the issue, by using terms incompatible or incorrectly. They've mixed them up.
