hello programmers,
Im using this encoder http://www.piekarz.pl/pl/?item=25879.
it's working only CW not CCW. I'm using arduino program like below.
Code:
// Setting up the counter
int reading = 0;
int lowest = -12;
int highest = 12;
int changeamnt = 1;
// Timing for polling the encoder
unsigned long currentTime;
unsigned long lastTime;
// Pin definitions
const int pinA = 12;
const int pinB = 11;
// Storing the readings
boolean encA;
boolean encB;
boolean lastA = false;
void setup() {
// set the two pins as inputs with internal pullups
pinMode(pinA, INPUT_PULLUP);
pinMode(pinB, INPUT_PULLUP);
// Set up the timing of the polling
currentTime = millis();
lastTime = currentTime;
// Start the serial monitor for debugging
Serial.begin(9600);
void loop()
// Read elapsed time
// Check if it's time to read
if(currentTime >= (lastTime + 5))
// read the two pins
encA = digitalRead(pinA);
encB = digitalRead(pinB);
// check if A has gone from high to low
if ((!encA) && (lastA))
// check if B is high
if (encB)
// clockwise
if (reading + changeamnt <= highest)
reading = reading + changeamnt;
else
// anti-clockwise
if (reading - changeamnt >= lowest)
reading = reading - changeamnt;
// Output reading for debugging
Serial.println(reading);
// store reading of A and millis for next loop
lastA = encA;
