rotary encoder for volume
96y
Joined May 8, 2019
38
I wanted to use a Teensy to control a DAW audio gui..... Just simple transports using buttons but 1 quality rotary encoder or pot for track
volume control. Most DAWs have a utility built in to re assign cc numbers...
For individual track volume would I want a pot or rotary encoder..???? The Teensy 4.0 has pins for both analog and digital...
is there a problem with using one or the other? and maybe you know....what digital pins do you use on the teensy for a digital rotary ??
I want the volume control to be stepped and be precise if possible..
