No,you misunderstood, even with enough gate drive you're still tying to dissipate 7.4W over a cycle. it simply can't be done with that MOSFET,or rather with only one of them. You need at least two, preferably 3.Hello Irving,If I understand you correctly first we need to open the mosfet NDT3055L.
The short answer is: you don't! The datasheet tells you what the device can deliver, not what will actually happen in your circuit. A Ferrari can do 200mph, but not if its stuck behind a tractor on a country lane! Anyway, increasing the gate current isn't going to solve the problem.the signal goes from UCC5304 device link shown below.
given the datasheet how do i know the amount of current which goes out of Vout?
Is there a way to increase the amount of current which goes out to open the gate of the NDT3055L mosfet?
Thanks.
https://www.ti.com/lit/ds/symlink/ucc5304.pdf?ts=1714595723865&ref_url=https%3A%2F%2Fwww.mouser.co.il%2F
