Robot project using STM32G474 MCU
djsfantasi
Joined Apr 11, 2010
9,237
No progress, just stuck. Some suggestions are way beyond me i.e. LED flash - don't know what it is. So, helpless.
LED flash is beyond you? Where are you from, in case there is a language problem we have to overcome.
Flash or blink. Either action is what was asked of you. Led turns on, there’s a short delay, LED turns off, another short delay. Repeat forever. Program code to do this, connect an LED and resistor to the MCU and load the program.
beatsal
Joined Jan 21, 2018
425
Thanks. Got it. From Canada, so no lang. problem. I do have a programmer that is not called LED programmer, so was a tad confused. Wonder what is the next step.
35,082
Fine. The next step would be to get STM32CubeIDE up and running and attempt to download a dummy shell program to your target MCU.
If you don't know how to do this I can take you through the steps.
35,082
Invoke STM32CubeIDE
Step 1 - Select New > STM32 Project
Step 2 - Target Selection > Select STM32G474VETx > Next
Step 3 - Enter Project Name > Finish
Step 4 - View Workspace > Core > Scr > main.c
Step 5 - Attempt to compile and run
Step 6 - Compiler runs. ST-LINK fails to connect.
Step 7 - Connect ST-LINK and try again. Click on Debug icon.
That's it.
If that works then you can go back and reconfigure your project in order to try a "Flash LED" test program.
