Rise And Fall Detector
maker_2023
Joined Nov 20, 2023
199
Hello:
I am trying to simulate a rising edge and falling edge detector using a CD4093 NAND gate
with Schmitt trigger inputs. I get the following message wrt the gate.
U1:eek:ut:b1"Unknown circuit node:"vdd" requested in behavioral source.
Can someone please tell me how to fix this?
38,860
You are apparently using the CMOS model library (.lib cd4000_V.lib) that needs a positive voltage source with its output node labeled "Vdd" (no quotes) to provide its power, so change the label +5V to Vdd.
Vdd can be any value from 3V to 15V, and the CMOS input logic and output voltage levels will correspond to that.
ericgibbs
Joined Jan 29, 2010
21,592
hi m,
Try what @crutschow suggested.
E
There are a number of different versions of the CD4000 lib, the suffix v version needs the VDD that was noted.
E
ericgibbs
Joined Jan 29, 2010
21,592
hi m,
Look in your LTSpice folder, it should be in Documents, find the lib folder, look and see which CD4000.libs you have in the folder.
E
