Ripple Voltage
david mendes
Joined Mar 23, 2006
6
Hello
Does anyone know how to calculate the Ripple Voltage on a half-wave rectifier circuit and on a full-wave?
I found the following formulas but when I compare them with what I get on the oscilloscope, the difference is huge!
Ripple (half-wave)= 4,5 x I(mA)/C( μ F)
Ripple (full-wave)= 1,7 x I(mA)/C( μ F)
Cheers
David Mendes
22,116
Originally posted by david mendes@Mar 23 2006, 02:03 PM
Hello
Cheers
David Mendes
[post=15349]Quoted post[/post]​
The problem could be the constant or it could be the units that you are mixing. That is mA and uF. The approximations are derived from the following equation
Rich (BB code):
dV/dT = - I/C
where
dV/dT is the voltage sag from one rectified peak to the next. dT will be 8.33 milliseconds for the full wave case and 16.67 milliseconds for the half wave case.
I is the current in Amperes
C is the capacitence in Farads.
In a less tha rigorous fashion this leads to
dV = dT*(I/C)
So using 0.00833 or 0.01667 for dT and I in amperes and C in Farads do you get more consistent results?
david mendes
Joined Mar 23, 2006
6
Where do the 8.33msec and the 16.67 msec come from?
Cheers
david
22,116
Cheers
david
[post=15522]Quoted post[/post]​
8.33 msec is the time from one peak to the next peak of a full wave rectified 60 Hz. sine wave, and 16.67 msec is the time from one peak to the next peak of a half wave rectified 60 Hz. sine wave.
Naturally if you are outside North America your sine waves will be 50 Hz. and not 60 Hz., and if you are on an airplane they will be 400 Hz.
gladeeader
Joined Oct 26, 2008
2
I was a little bit worried about the age of this thread, but i figured i'd try it anyway. Also thank you for replying. I'm just getting into some of my electrical engineering classes and this helped me out a lot. and a couple of my peers as well. thank you very much for sharing your knowledge so freely PapaBravo
