A couple of weeks ago I bought this model from Amazon and recently discovered an issue with Channel 2's waveform, (noise), jumping high by about 5 mV. Set the time base to a fairly quick 1 uSec or so for a fast sweep. With both probes disconnected, enable Channel 1 and set to about a 1 volt/div. Hit the Channel 1 "zero" to see that the signal is coincidental with the horizontial axis. Now enable Channel 2 and set to a low, (10-20 mV div) to better see the issue. Then with ANY channel 1 volts adjustment or hitting the Channel 1 "zero" button, see if the Channel 2 display jumps up - positive by abut 5 mV or so. see pix. Then if you turn off Channel 2 and then turn on again, the Channel 2 sweep will "reset" itself back to a true zero reference with the horizontal axis. (After hiting the Channel 2 "zero" button, the signal still stay high).... Rigol support said they could not duplicate the issue, (I'm skeptical).... and instead of exchanging for a new unit from Amazon, I FOOLISHLY spent 56 damn bucks to sent to them for "repair". IF I had known the FL to OR shipping would be this high, I would have/should have made the exchange. The pix illustrate the issue and I'll appreciate any feedback from users of this model line of scopes.... Thanks for your replies...
