Rigol DS1202Z-E date is incorrect .. can I change it?
albireo13
Joined May 7, 2013
26
I have this scope and have been storing screenshots to my USB drive. However, the files that the Rigol creates has a date that is totally incorrect, by about 10 years. I have been looking for ways to correct a date setting in the scope but no luck. It seems that its TOD clock needs to be updated.
Has anyone else found a fix?
Thx
WBahn
Joined Mar 31, 2012
33,137
I didn't see anything in the DS1000Z User Manual, so I asked Copilot and it returned the following (Keep in mind, this is AI-generated using an LLM, so it may bear no resemblance to reality. Let us know one way or the other if it was close).:
To set the date on a Rigol DS1202Z-E oscilloscope, follow these steps:
  1. Power on the Oscilloscope: Ensure your oscilloscope is turned on and fully booted.
  2. Access the Utility Menu: Press the Utility button on the front panel.
  3. Navigate to System Settings: Use the navigation buttons to find the System option in the menu.
  4. Select Date and Time: Within the System settings, look for the Date and Time option.
  5. Set the Date: Use the navigation buttons to adjust the date settings. You can usually set the year, month, and day.
  6. Confirm Changes: Once you've set the correct date, confirm the changes and exit the menu.
If you need more detailed instructions, you can refer to the user manual for the Rigol DS1202Z-E.
Is there anything else you'd like to know about using your oscilloscope?
Hymie
Joined Mar 30, 2018
1,347
WBhan
'There are 10 types of people in the world: those who understand binary, those who don't, and those who can work in any number base.'
Surely that's 11 types of people?
albireo13
Joined May 7, 2013
26
I have tried that but under System, there is no Date and Time sub-menu.
WBahn
Joined Mar 31, 2012
33,137
WBhan
Sayeth a person not of the last type. ;)
