Right value for low-pass filter capacitor ?
dr.emp
Joined Nov 13, 2017
8
I am using this RF receiver microcontroller I had from an old teardown of a rc car. The schematic of the IC is here:https://www.diodes.com/assets/Datasheets/PT8A977B978B978BL.pdf All values for the components are specified on page 9, except for C6.
My question
: Is R1 and C6 some kind of low-pass filter ? If yes, then what value should C6 be ? And can I calculate that value with the formula f= 1/2pi*RC ?
ericgibbs
Joined Jan 29, 2010
21,571
hi dr,
The C6 value for tuning the frequency.
E
Woops incorrectly read the capacitor notation.!
MOD: Clipped and posted the circuit, easier to read.E
dr.emp
Joined Nov 13, 2017
8
Thanks for the answer. Well i asked around in other forums and they told me it was this or that, but they never came to a conclusion. So I applied the values of C3 (10pF) and L1(calculated by measuring the coil, can't remember the value of it) in the formula f= 1/2pi*square(LC), resulting a resonant frequency of about 25 MHZ, which I supposed that can be leveled up with the core of the inductor.
Maybe I should have mentioned that I want it to receive in the range of 27 MHZ ?
dr.emp
Joined Nov 13, 2017
8
Thank you very much :). It was the last component I had to solder to the PCB. I was thinking about using LTSpice like you did, but I didn't know how to make the antenna. I want to use the circuit to control a Lego Technic car.
dr.emp
Joined Nov 13, 2017
8
UPDATE : The circuit still doesn't work. I replaced C1 by a trimmer capacitor ( 5-15 pF ). I'll review the circuit, maybe I forgot to solder some of the Connections, who knows...
