Hello there Sir, hope Ur still here in this page, got the same problem with your Altec Lansing, is the capacitor that you've replaced solved the problem of the right channel problem? thanks for your reply...Ok Second Problem with the volume control FIXED!
@ebp it turned out that your intuition was spot on while replacing the other volume control IC I created a tiny solder bridge (or maybe just some conductive dirt) got between pins 12 (LT2) and 13 (AGND) effectively shorting it. I was nearly going to remove the resistor to test and decided to reflow and clean that area first. Tested with Multimeter and it was measuring correctly again!!!
So all fixed!!! Couldn't have done it without you guys! That thing has been lying in my basement waiting to be fixed for months. Glad I found this forum. I will definitely be back. Special thanks to @ebp ...your judgement and intuition were invaluable!
Moderator edit: New thread created from this.
