Right angled pin-headers of different lengths?
seanspotatobusiness
Joined Sep 17, 2016
210
This picture shows an adapter board which is intended to go into a solderless breadboard. The right-angled header pins at the bottom must be of different heights in order to enter the PCB at different places but end at the same place on the bottom of the object. How do I find right angled headers of two different lengths, like this? Thanks.
dl324
Joined Mar 30, 2015
18,472
If this was for one or a few boards, I'd just buy a standard double row right angle header and modify them. It can be a pain, but I've done this. Not because I needed something like your application, but because I had 2x17 and I needed something like 1x5. I used cutters like the one shown below to customize length:
Then I pulled out half of the pins, cut the polyester bit, and reinserted the pins.
If you're okay with the lengths being off by 0.01", you could order standard single row parts:
