RFID Tag Design for Angle of Arrival Estimation
c0r3y123
Joined Dec 13, 2024
I'm at a fork in the road. I'm trying to create a tag that has two antennas, and I want to find the difference in time between when the signal arrives at those two antennas. That way, I can correlate the time difference with the angle of the receive signal. I have two ideas, but I think I need to provide some background.
Background: In a normal RFID system, two tags (with two antennas total) would each backscatter their own signal to the RFID reader. You can then find the time difference between when the reader's transmit signal "hits" the two tags by (first) finding the phase difference between the reader's transmit signal and reader's receive signal for both tag and (second) subtracting those two phase measurements to get the time difference. This works because change in phase is linearly proportional to distance, and distance is linearly proportional to time (constant speed of light). The big problem is when two RFID tags are nearby, the phase measurements gets distorted (phenomenon known as mutual coupling)
Idea #1: To get rid of phase distortion when multiple tags are close, my idea is for the reader to send data to all the tags but one tag, and tells them to not transmit anything (or open-circuit the tag antenna). That way, only one tag responds, so maybe now there's no mutual coupling. Then, you simply loop through the array of tags to hopefully get accurate phase measurements for each tag.
Idea #2: To get tag array orientation, measure the time difference of adjacent tags with a capacitor. Each tag has a capacitor that will start charging up at different times depending on which tag the reader’s transmit signal hits first. Assuming the capacitor hasn’t been saturated yet, the charge rate over time should be close to linear, so voltage and time have a linear relationship. By subtracting the capacitor’s voltage, you will also get a value that’s linearly proportional to time. You then backscatter that voltage value to the reader, and simple code can find the time difference. This method does processing on the “tag end” rather than the “reader end”, so I think you avoid distortion in phase; my concern is that the resistance and capacitance values need to be really accurate because the rate of the capacitor's charge over time needs to be same for many tags. Also, this circuit design, I believe, is just an RC integrator.
TL;DR: I'm designing a system to measure the time difference of signal arrival at two RFID tag antennas for angle-of-arrival estimation, addressing mutual coupling distortion. Idea 1 avoids mutual coupling by activating one tag at a time for cleaner phase measurements. Idea 2 uses capacitors on tags to locally measure and backscatter the time difference without relying on phase, reducing distortion.
I give absolute permission to criticize my ideas (just explain why, thanks!).
