Rf power detector
lucasN6676
Joined Feb 20, 2024
18
Hello everyone,
In this circuit, what is the importance of a logarithmic amplifier other than achieving a linear dB output? In all the papers, it is stated that it extends the dynamic range. How is that possible? Isn't the dynamic range already defined by the RMS power detector?
BobTPH
Joined Jun 5, 2013
11,615
Yes, but it is also said in the papers that they extend the dynamic range
Imagine this. You want to measure power over a range of 1uW / m^2 to 1W / m^2 (not sure these are the right units, but it is only the ratio that matters).
So you create a circuit that converts it to a voltage from 0 to 10V
So, 1uV = 1 uW, 2uV = 2uW
So for the level of uW, the next value would be 2uW. You would need 1uV accuracy at that level to get an error up to 100%. Meanwhile, at the top of to range, there is a difference of 1V is goes from .5W to 1W. So the resolution is very good on the high end, very bad in the low end.
Now change it to the log base 10 of power. So 0V is 1uW, 1V is 10uW, 2V is 100uW, 3V is 1mW, 4 is 10mV, 5V is 100mW and 6V is 1W.
That gives you a consistent ratio for each unit of output. This allows for similar accuracy across a large range using the same precision. In this case, 1mV resolution can give you precise results across the entire range.
