Total newbie here...
I'm researching how to detect broadband noise, and wanted to see if I have the basics correct.
Let's say the noise spectrum is wide ranging, from DC to over 100MHz, and I was interested in looking at the noise power between 47.5 and 52.5MHz (for example).
For noise detection, I would use some RF noise detection IC, TBD.
But first I should probably downmix. If I use an LO at 53.5 MHz, then the input is downmixed to 53.5-50 = 3.5MHz, start =1MHz, stop = 6MHz.
But before I downmix I should probably LPF with cutoff above 52.5 MHz, so that higher frequencies don't pollute the window I'm inspecting?
And after I downmix I should BPF between 1 and 6MHz?
My ultimate goal is to have the frequency window of interest be adjustable, which complicates how the filters and LO are designed.
