RF enabled power supply
Muncle
Joined Oct 3, 2019
Hello all. I'm attempting to design an RF enabled battery powered design. I have a small AAAA powered pcb with a pic and a SI4467 XCVR communicating at 915MHz with another system. This part is designed and working with the help from SI4467 reference designs. However, per external requirements I need the circuit to only operate in the presence of a separate 868MHz signal (non latching). Rather than putting things in sleep/shutdown mode I need to disable the dc/dc converter because there are various other parts (pullups etc) that will drain the battery. I will need to use ANT-868-CHP-T chip antenna.
It was suggested elsewhere that I use the following circuit to generate an enable signal for the power supply...
SI AN768 suggests using the following matching circuit for the before mentioned chip antenna...
That all being said, RF is my weakness and I'm not sure what the thinking is behind the enable circuit (Aside from the high side switch). I've tried simulating all this in ltspice and it doesn't seem to work but I'm sure I am missing something.
Attached is the .asc file for the simulation. In the simulation I'm alternating between switching in an 868MHz signal, no signal, and a 915MHz signal and would like to see the enable go high only in the presence of the 868MHz signal. I know I need some filtering but I'm not sure how to in conjunction with the suggested circuit.
Help!
