Revised Howland Pump - Choose Sense Amp
Vinnie90
Joined Jul 7, 2016
86
Hello everyone,
I'm trying to design an Howland pump which should drive an inductive load (1H, 50ohm) with a variable current (-100 to 100 mA). I have simulated the circuit using high CMRR op amps (~80dB) and to decouple the input and the output I have placed a buffer in the feedback path (see schematic). I'm having troubles in selecting the correct opamp for the feedback (as long as I use an ideal op amp I get the right current, while when I switch to a another amp I start seeing probelms).
Thanks for the help :D
Vinnie
38,526
You need a high power op amp that can supply 100mA.
Standard op amps usually have a maximum of about 20mA.
You could add a current booster circuit to the output of a standard op amp, if you prefer.
Vinnie90
Joined Jul 7, 2016
86
Thanks for the quick answer. Well, the current is provided by U6 which can give 500 mA. U1 doesn't seem to output a lot of current because it's just buffering the voltage.
Vinnie90
Joined Jul 7, 2016
86
You have the power supply polarities reversed on U1.
It doesn't like that. :rolleyes:
Also C1 and C2 do nothing.
Oh man you right!! Now it's working smoothly! C1 was supposed to be in parallel to the negative feedback resistor to filter out the noise
Thanks again :D
