RRITESH KAKKAR
- Joined Jun 29, 2010
- 2,829
i don't know very well how to use kvl
Yes, so what is the current in Z, and after that, what is the voltage across Z?(180-30j ) // (0+30j)
0+5400j+0-900j²
5400j+900/180
30j+5
then 5+30j+5-30j
10ohm
Yes, it's important to keep the voltage in complex form. Now work out the voltage divider consisting of Xc2 and R2.OK, 10V/10= 1amps.
10*30j+5/30j+5+5-30j
10*(30j+5)/ 10
5+30j can voltage be in complex form?
OK, but one thing you should be careful to do is include parentheses in the numerator and denominator, otherwise the order of operations on a calculator, for example, might not give the correct result. Do it like this:5+30j*180/ 180-30j
900+5400j/ 180-30j
90+540j/18-3j
30+180j/ 6-j Volt
I disagree.Electrician -- I say this then I'll stop cuz I'm interrupting lessons
Saying someone lacks talent or aptitude is to say they're congenitally defective! NOT COOL!!!
Absolutely correct!(30+180j)*(6+j) /( 6-j)*(6+j)
180+30j+1080j-180 / 36+6j-6j+1
1110j / 37
30j Volt
If you think it would be better to discuss Q with RRITESH, then by all means start a new thread. In this thread Q comes later.If just for language barrier then I understand is ok but content is too basic I mean resonant networks without talking about Q?
The reason j is there is because the voltage across R2 is shifted in phase, 90 degrees, with respect to Vs.now.
i used to study whole night in exam.
So we see that a source that is supplying only 10 volts, is able to drive the 180 ohm resistor to 30 volts.
What does 30j mean?
if there is j that mean 90 phase out?The reason j is there is because the voltage across R2 is shifted in phase, 90 degrees, with respect to Vs.
The problem now is to design a matching network to match predetermined source and load impedances.
Exactly. In English we would say "90 degrees out of phase".if there is j that mean 90 phase out?
I've edited post #25 because I inadvertently labeled both inductors L1; now the second one is L2.I think as you said first step is to find impedance at load 50ohm by Thevenin.
(6+4j-Cj) // L1
Hi, RRITESH![]()
(6 + 4j - Xc*j) || (Xl2*j)
why we have not consider 50ohm?
(6 + 4j - Xc*j)*(Xl2*j) / (6 + 4j - Xc*j) + (Xl2*j)
6*Xl2*j + 4j*Xl2*j - Xc*j*Xl2*j / (6 + 4j - Xc*j) + (Xl2*j)
6*Xl2*j - 4Xl2 + - XcXl2 / (6 + 4j - Xc*j) + (Xl2*j)
