where is 4ohm here?We have a 10 volt source with an impedance of 4 ohms
where is 5ohm gone?While you're doing the calculations in post #21, a related calculation I'll ask you to do is this.
Calculate the impedance looking into the circuit from the side driven by the voltage source:
Sorry. Make that 5 ohms.where is 4ohm here?
It's not there any more in this circuit. We want to know what impedance is being driven by the source with its 5 ohm impedance.where is 5ohm gone?
(180-30j)//(0+30j)While you're doing the calculations in post #21, a related calculation I'll ask you to do is this.
The C and L will cancel as it is in balance.Finally, we have this circuit:
We have a 10 volt source with an impedance of 5 ohms driving through some reactances to a 180 ohm load. Can you calculate the voltage across the 180 ohm resistor, the voltage at node 4?
Yes, this is correct. This result shows us the impedance matching in action. We have a 180 ohm load at R2, but the voltage source sees a 5 ohm load. Since the voltage source has a 5 ohm internal impedance, and it sees a 5 ohm load, we are getting maximum power transfer our of the voltage source. But the voltage across a 180 ohm load would need to be higher than 10 volts to be equal to the power out of the source. Where does that higher voltage come from? It comes from the voltage rise that the series resonant circuit in post #1 provided.(180-30j)//(0+30j)
0+5400j+0-900j²/180 as j²=-1
5400j+900/180
30j+5
5+30j-30j
5Ohm ,right?
How the source see 5ohm internal Resistance?This result shows us the impedance matching in action. We have a 180 ohm load at R2, but the voltage source sees a 5 ohm load. Since the voltage source has a 5 ohm internal impedance, and it sees a 5 ohm load, we are getting maximum power transfer our of the voltage source. But the voltage across a 180 ohm load would need to be higher than 10 volts to be equal to the power out of the source. Where does that higher voltage come from? It comes from the voltage rise that the series resonant circuit in post #1 provided.
The source doesn't "see" a 5 ohm internal impedance. The internal impedance of the source IS 5 ohms. That is why we want a load of 5 ohms, because that will match the internal impedance of the source. We want our real source (Vs plus R1) to "see" a load of 5 ohms. The load the source sees is the circuit of post #22.How the source see 5ohm internal Resistance?
I think it would be better if HP didn't intersperse his comments with the flow of my explanations. You could follow up on the other long thread if you want to understand his comment.What is this and use?
No, this is not correct. You correctly calculated the current in the circuit of post #1 as 2 amps, but that is not the current in the circuit of post #21. You need to analyze the full circuit of post #21.The C and L will cancel as it is in balance.
So, 10V/5=2Amp current
V=2*180=360V
AFAIK it's not a competition.I didn't realize this was a competition?![]()
I stopped contributing over there because it seemed to me that RRITESH was being confused by multiple suggestions from multiple posters. My contributions were mostly not directed at helping RRITESH solve the impedance matching problem anyway. I did want to offer suggestions toward the solution of that problem, and I started a new thread so I could offer a different line of instruction with continuity rather than as interjections to your line of instruction.You were and are free to contribute to the thread on 'homework'
It is my intention that this thread NOT be a continuation of your "line of instruction"; it is different. It concerns the same topic, but is not a continuation of your "line of instruction".Inasmuch as this is a continuation of the 'line of instruction' I began with Rritesh some weeks ago --
There's no reason for you to abandon the discussion, which, AFAIK, is still in progess over at the other thread.I cannot, in all good conscience, abandon the discussion
OK, so this value becomes Z, a temporary impedance. The circuit is now like this:![]()
In this circuit which mesh calculation kvl and kcl?
(180-30j ) // (0+30j)
0+5400j+0-900j²
5400j+900/180
30j+5
so, (5+30j) // (5-30j)
25-150j+150j-900j²
25+900/10
2.5+90
92.5ohm
so, total current is 10/92.5=0.108mA
after this voltage divider at 3 node
10*(5+30j)/(5+30j)+(5-30j)
50+300j/ 10
5+30j
