Resistor to be used in Driven RL/RC
hunter6
Joined Feb 22, 2018
35
Here are two circuits. One with a voltage source and other with a voltage source. I see in my solution manual that :
For the first circuit (voltage source) ,only one resistor (100 ohm) is used to calculate the value of T (Tau). i.e L/R.
However in the second circuit (current source), resistors are first added in series and then their equivalent value is used.
why is this contradiction?
Jony130
Joined Feb 17, 2009
5,601
Because you have an ideal voltage source. Hence the voltage across left 100 ohms resistor is always equal to the voltage of a ideal voltage source. So, no effect on the rest of the circuit .
But this is not the case in terms of a current source becouse now you have current divider ( the current will split between R and LR network).
And a tip. If you want to find an equivalent resistance seen from any component point of view you should always replace all voltage source with a short circuit and all current source with an open circuit. Just like we normally do when we are trying to find Thevenin's equivalent resistance Rth.
hunter6
Joined Feb 22, 2018
35
So , If I talk about this circuit , The Resistance to be used in R/L , will the parallel equivalent resistance ? (60 || 60 || 60)
Considering that we kill the sources.
