Resistor Cube Properties
MrAl
Joined Jun 17, 2014
13,810
Hello there,
I started working on the resistor cube problem that we started thinking about in the resistor grid thread. Here are some results:
Code:
  Resistor Mesh Cube
  N    V            R
  1  4.000000  8.333333
  2  3.255814  10.238095
  3  2.967581  11.232493
  4  2.813628  11.847100
  5  2.718043  12.263726
  6  2.653020  12.564298
  7  2.605965  12.791168
  8  2.570354  12.968384
  9  2.542474  13.110588
  10  2.520060  13.227196
  20  2.418082  13.785033
  25  2.397487  13.903444
  N is the number of resistors on one edge, so number of nodes on one edge is N+1.
  V is the voltage at the corner across one resistor that goes to ground.
  R is the total resistance across two opposite 3d corners.
  10v is applied to one corner, 0v to the oppositve corner.
  Note that the "opposite corner" is across the center of the cube not just across one surface.
  The solution with applied voltage across opposite corners of just one surface is a different problem.
  All resistors in the cube are 10 ohms each.
The only problem i ran into was that i was not able to verify the results for N>2 because i did not have any secondary method to calculate these values yet. They do look reasonable though, and the cube grid node values all look reasonable with the characteristic 1/2 Vcc showing up across a surface internal to the cube as expected (the 2d grid showed this behavior across the minor diagonal).
If anyone wants to try to verify any of these values that would be great.
MrAl
Joined Jun 17, 2014
13,810
Hey there.Were you able to verify any of these values? I ran into the same problem when working on the coding for <SNIP> (somehow it seems quite related but I cannot solve it)
Hello there,
Was that by any chance the coding for how to get free advertising :)
I did not revisit this problem yet since the time of the first writing as i have gotten involved with other things since then.
I suppose i could set up a regular 3d Nodal analysis but didnt get to do anything like that yet. The current method i use is to solve a discrete version of Laplace's equation in three dimensions as that is the fastest and requires the least storage.
If i get a chance maybe next week i might be able to verify some of those numbers using a regular Nodal type analysis.
The cube is a little interesting to me because it is like a discrete version of a solid piece of conductive material.
