Unless 3.3V is connected ONLY to those resistors, then everything that is powered by 3.3 V is in parallel with the resistors.
If you wait long enough, the reading will likely stabilize, but it could take minutes as capacitors throughout the circuit dis/charge to stable voltage. If there are large capacitors, it could take tens of minutes.
[EDIT] even after stabilizing, the readings won't be correct
