Request for advice for a custom project
mshlama
Joined Sep 18, 2013
3
Questions:
1) What is the more appropriate processing power for this application: a computer, microcontroller, or other?
2) a) if computer which software(language) would you recommend for this application?
b) if microcontroller which one would you recommend for this application?
This is the application -
Input: device processes/recognizes audio input (such as a dog barking or someone shouting) - most likely with a microphone
Process: the device then waits for the input to stop (even momentarily) i.e. the dog stops barking or the person shouting takes a breath) and then send a signal to begin the output
Output: graphic to an LCD (any size) or play a pre-programmed audio file (i.e. mp3) most likely with a speaker
About me: I'm a beginner to intermediate programmer with experience in C, Fortran and Java. I also have some exposure to microcontrollers through a Basic Stamp microcontroller. What I am most unsure about is how to deal with the audio/listening part of this application i.e. to listen for a specific sound and then recognize when it has stopped
Thank you in advance if you decide to leave any comments/suggestions/advice.
33,123
So a dog goes, "Ruff, Ruff, Ruff," and you want to start the output after each "ruff"? After all, there is a momentary stop between each individual bark. Same thing with someone shouting -- there's a momentary silence between each word.
You need to define your specs a bit more fully.
mshlama
Joined Sep 18, 2013
3
Yes that is correct. Begin output as soon as the first ruff/shout is complete. Output should occur right at momentary stop, before the second ruff/shout.
Sorry for not defining the specifications more fully.
mshlama
Joined Sep 18, 2013
3
Yes, that is correct. The goal is to see if what kind of outputs that can get the object to stop barking/shouting.
JBernard
Joined Aug 8, 2013
46
sounds like it could be done with an arduino and a electret microphone
heres a volume detection sent back out to a light bar, you could just adjust the sensitivity of what triggers it, then use that to play a sound file.
http://negativeacknowledge.com/2008/06/11/final-lightbar-controller/
you could have your sound file on an SD Card shield on the arduino, for playback.
and you could make the whole unit remote/wireless by having battery packs to power the arduino and possible onboard speaker.
