Request for a 5W transistor controlled LED flash light controller circuit review
Hasan2019
Joined Sep 5, 2019
210
circuit is useless and makes no sense. plus it is drawn wery awkward.. R3,R4 are in parallel with R5 but places far away, with additional line crossings. placing three equal low value resustoprs in parallel would suggest there is high current through them, but it cannot be - at lest not from what you have drawn. because there are exactly three paths leading to this resistor back:
R9 sets the threshold at which Q1 begins to turn ON.
Q1 converts the slow RC voltage ramp into a sharper transistor switching waveform.
R2 ensures Q1 switches smoothly instead of snapping abruptly.
R3/R4 ensure the LED receives safe, controlled current.
a) R7 which is way to high and would limit such current.
Current limiting is problem here ?
b) Q5 which is also a dead end - C1 can be charged by currents through R9 and R2. both of which are way too high to make any difference for three 5.1 Ohm resistors in parallel.
Q6 is the master controller that decides when the LED driver section turns ON or OFF. If we improve the Q2 connection it will be better.
c) Q2 which is completely dead - no current flows through here.
Q1 emitter is connected to Q2 collector, and its base is in GND, it’s a problem.
Can we change here likewise,
  • Q1 emitter → small resistor → GND
  • Q1 base → bias/timing network (via R9, etc.)
  • Q1 collector → R7 → Q2 base
  • Q2 emitter → small resistor → GND
  • Q2 collector → R1 → Q6 base
It can improve, Q1 responds to the timing voltage. Q2 amplifies Q1’s output, Q6 gets a strong, well‑defined drive.
next, D1 is a dead short for reverse polarity. so connecting AC to J1 would blow it up.
SW2 and everything right of it does nothing. when SW2 is in position:
Leve D1 at this moment.
1. current through R8 has nowhere to go. on one side is insulator (gate of Q5), and the other is through Q3 with nothing to drive its base.
Is its same now in post #5 ?
2. not connected to enything so - nothing.
3. R11 conly connect to C2. 1uF make no difference anyway since it would be in parallel with C3 and C4 which are 2000x larger capacitance.
finally there is no load. for any circuit to do something, there meed to be some sort of load or "business end". this circuil lacks scuh thing. if J2 is meant as place to connect load (like 5W LED), then i am sorry to dissapoint you, R7 is a major problem to getting those 5W out.
Load is not mentioned here, it is a three‑transistor amplifier chain (Q1 → Q2 → Q6) that takes the slow timing signal from the RC network and turns it into a strong switching signal that controls the LED driver.
I looked at the initial schematic and my eyebrows furrowed, then arched up. It's a very complicated solution to accomplish the goal.
A much reduced circuit with a timing source (555-based or some other clock signal), a few passives, and a low rds-on power MOSFET switch could be used for a load like a 5 watt LED.
I'm a partisan of simpler, more robust, low-tech solutions to electronics needs or issues. My former employer appreciated that a lot.
Just my two cents...
Hasan2019
Joined Sep 5, 2019
210
@Mike VE2TRV could you kindly share any similar design is this regards ?
panic mode
Joined Oct 10, 2011
5,420
no offense but who ever gave you this circuit was high as a kite. the only time i have seen something like was in cartoons.
cartoons of course were meant as a joke. asking people to give serious consideration to rubbish you posted is ... insulting. but i did give you chance anyway by stating what was wrong with it. there is nothing there to even begin looking at. if there is a power source that connects to J1, it is not known. that alone makes it nonsense. same goes with load. you mention 5W LED but never which exact one. if this is created by AI, choose different AI. if this is something you cam up with, i would say try wiring it up. smoke and burned skin are excellent teachers.
i actually like this circuit way better:
Hasan2019
Joined Sep 5, 2019
210
It may make you laugh, seems joke or else. It may be completely "non-sense" to you. Better to say it's a back box. If I were you I won't spend time here where I can not recognize how circuit works.
28,502
Certainly the original circuit posted was both overly complexas well as being non-functional.
Unlike any "cartoon" it did not make me laugh or even smile. Attempting to even understand the purpose was a challenge.
AND, a noteof caution: bicycle generators/Dynamos often have one side tied to the frame ground. This is a terrible flaw that I have come across..
panic mode
Joined Oct 10, 2011
5,420
if you need a circuit, why don't you simply state what is it that you need? post real specs like supply voltage, load data sheet, describe operation (incl sequence if any...) that would be kind of help request, i can get behind.
but please do not insist on discussions on something that cannot possibly work, and have us try to decipher what the heck was that supposed to be. you have received plenty of comments that all agree that circuits you posted are complete nonsense. how much convincing do you need?
schmitt trigger
Joined Jul 12, 2010
2,276
It is not only him. No one so far understands it either.
All I can tell you us that everyone who has answered so far, has 40, 50 or more years of direct electronic experience. If we can’t understand it, is because of it being nonsense.
28,502
What is required is a scheme to compensate for the wide voltage range from the bicycle alternator, which certainly, in addition to having poor voltage regulation, has an output that varies a whole lot even with a constant load.
The generaator output requires not only regulation, but also over-voltyage clamping.
ronsimpson
Joined Oct 7, 2019
4,853
It has been a while since I did one of those.
Last time I wanted to get a LED that could take full power when at high speed and not regulate at all. Very simple.
But the light goes out when the bike stops. It was determined the light needs to stay on for two minutes after the bike stops. So, we had to add a large capacitor/battery that needs to charge up and last for a short time. (as long as the wait for a red light plus some)
A power LED is like a power Zener diode. It will voltage clamp just fine. Full wave bridge, LED, no capacitor or small cap.
A car batter is also much like a Zener. It clamps the alternator's voltage while charging.
28,502
Voltage clamping can work ONLY if the source of the voltage being clamped is not going to deliver more POWER than the clamping device can dissipate.
As for the typical battery in a car, once it is fully charged it does not continue to charge: It gets hot and eventually boils. I saw that in a 1966 Rambler, first hand. THAT is part of why we use voltage regulators!!
ronsimpson
Joined Oct 7, 2019
4,853
Can a bicycle generator make more than 5 watts?
We have a 5w LED and perhaps a battery that could run in parallel. If needed, we could bolt a 100-watt resistor to the frame of the bicycle. I don't think overpower is the problem. I think under power is a problem.
----------edited----------
I found several alternators rated for 5.5W in the data sheet and sold as 6W. There are some at 3W and one at 0.5W.
What does "ride very fast" indicate? I don't know how fast to get 5.5W.
wayneh
Joined Sep 9, 2010
18,181
Yes, I think the standard, old-fashioned bottle dynamo was a 6W nominal. The bike probably had to be going >15mph to hit that. I'm not sure what happened with those if you hit 30mph. Now with LEDs, there's no need for that much power drain on the rider.
panic mode
Joined Oct 10, 2011
5,420
an example of 5W white LED specimen is multicomp 703-0116:
https://www.farnell.com/datasheets/1678767.pdf
this one is star with 4 element COB (2 in series and 2 in parallel). and with If of 1A has Vf of some 5V. specs for other products may vary.
this is just an example of info that should have been shared in the first post, along with rest of the specs or parts info.
if using something like that, i would consider having a battery and suitable LED driver. if battery is LiPo 3.7-4.2V, suitable driver IC could be something like PAM2804. this kind of setup makes it easy to charge it by USB charger when offline and since it is low voltage, it can be conveniently charged from many other sources (including those with higher voltage). for example LT3652 (5-32V input!) or one of BQ2xxxxx from TI or similar. all of this is easy to source, proven technology with products that have reference circuits and manufacturer support. something like this is an example of solution that is anywhere from very low risk to guaranteed to work. this operates at high efficiency and it is a complete opposite of cartoon like circuit. LED and LED driver need proper cooling. if this is fed from an AC source, bridge rectifier and filter cap are needed.
ronsimpson
Joined Oct 7, 2019
4,853
On a different group I suggested this emplace of the LED. I might have posted the schematic of the light bulb. This makes the LED circuit simple. I see them for $3 on amazon. I might still have some prototypes in a box somewhere.
