Replacing variable POT with push button
North_south_cosplay
Joined Aug 1, 2019
16
so far you guys in here have been PERFECT with my enquires so I'm hoping you can help one more time :). I have a variable POT like a dial and it moves my servos up and down with the turn. Is there anyway I can replace it with a push button so when I press the button it moves the servos down and then when I release it returns the servos back up. Thanks again for all your help guys. My spiderman mask is nearly complete
MaxHeadRoom
Joined Jul 18, 2013
30,772
Isn't this an off shoot of a previous post?
Don't you only need 2 positions?
If so the ordinary PB should work with a default home position when OFF.
Max.
North_south_cosplay
Joined Aug 1, 2019
16
Max.
Yeah it is bud. if someone had the time I'd need the process explaining to me a little. The variable POT has 3 connectors including 2 on the side. So I'm in unknown waters here
