Replacing power supply in a "coolest Cooler" Help for a none electronics guy
bmklawt
Joined Dec 27, 2013
8
In lockdown, because of COVID-19 thought I'd try to fix this just for fun, all I know of electronics I've learned from the internet so, please do talk like I don't know much because I really don't.
I have a nonfunctioning "Coolest Cooler" a now-defunct Kickstarter that made a beach cooler with a blender, USB charger and LED light and the only thing working on the cooler is the USB charger. I would like to replace the power supply but am not quite sure what to use, I assume the power supply is a motor controller for the blender motor a LED driver, I don't even know what an LED driver is or why you would need one and power for the USB charger.
I was looking at a 300W 20A CC CV Constant current adjustable buck converter step down voltage module for the power, the battery is a 21-volt Lithium-Ion battery and the blender motor is an 18V RC motor, I think this would run the blender motor but how do I power the LED and the USB charger, the USB charger has Bat+, Bat- and USB_DIS, what is USB_DIS? How do I not overheat the battery? Am I even on the right track?
This is what I know so far I have 21 volts at the USB charger and at the LED on/off switch.
The blender motor rated voltage is 18V and the voltage range is 3-21V, the no-load speed, and current value. 18V 22200 rpm 2.37A
Any guidance can get on this will be greatly appreciated,
Bruce
BobTPH
Joined Jun 5, 2013
11,661
Power supply usually refers to only the thing providing the power, not to a motor controller and LED driver. Since the battery is still operating the USB charger port, replacing it will not help, their problem lies somewhere else.
Have you checked for a blown fuse? If both those things stopped working at the same time, that seems like a likely cause.
Bob
bmklawt
Joined Dec 27, 2013
8
The original electronics board is shot, the only thing working on that is the power out to the USB board, I assume the original board is a power supply, motor controller, LED driver and power to the USB board. I purchased a 20amp DC-DC Buck Converter for the motor a LED driver for the light. I was wondering what the USB_DIS connection is for on the original USB board or can I just hook up the BAT+ and BAT- to the new power supply and forget about the USB_DIS connection, I don't want to overcharge a phone if I plug into the USB port or does the phone itself take care of that.
Thanks much for the help
