Repair welding machine
28,595
In a case like this it is very useful to have both a circuit diagram and a block diagram with a description of how it works. Then a description of what is not working is required. After that , a study of the circuit to see which parts failing would produce the problem seen.
If none of those items are available then the process is different, which is first inspect for failed connections and then check for failed parts. This method is far slower than using the understanding of how it works to see where the problem lies.
Semivosa
Joined Feb 4, 2019
This is for those who learn to repair welding machines and power electronics.
If anyone needs help in repairing the welding inverter, please, I will be happy to help.
Olá amigo tenho uma máquina de soldar Rowac 150E que liga normalmente mas não tem potência para soldar obrigado pela atenção...
