That circuit won't work without the buffer either.Wont work with 2n3904/6 efficiency isn't an issue for this.
Thanks for the modification, it works really well. It even remains almost undistorted to very fast frequencies.That circuit won't work without the buffer either.
It works with a redesign to give a properly operating sawtooth circuit by inverting the bottom transistor and separating the current-mirror circuit from the threshold circuit (why did you change the circuit from post #34?).
It has an output offset of about 200mV.
A 10,000 to 1 frequency range is generally to much for one range.Can this circuit still be made to oscillate 8hz to =>80khz?
