I am working on a lightweight, high powered LED system for a heavy-lift drone.
I am using 500w chips similar to these www.aliexpress.com/item/32719094567.html
And powering with a 6S (24v) 5000mAh LiPo battery via this DC booster www.aliexpress.com/item/32917133210.html
I have a solution to remotely switch my lights on and off using one of these www.superdroidrobots.com/shop/item.aspx/battleswitch-radio-controlled-10a-relay/827/
I use a Taranis XR8 as the RC receiver https://www.frsky-rc.com/product/x8r/
What I would really like now is a solution to dim the lights remotely.
Is there a way to somehow remove the CC (current control) unit from the PCB and attach something else that can be controlled with standard RC servo signals?
Or are there any other ideas to accomplish my goal?
