Relay triggering voltage
J253
Joined Dec 2, 2023
5
Hello all , I have made an optocoupler relay PCB.. that I'm using with my stm32 development board.. that relay power at 5V and triggered at 3.3V .. sometimes my controller board give less voltage like 3.2 or 3.21 at that time it's not triggering can someone tell me what's going on or help me ..
AnalogKid
Joined Aug 1, 2013
12,281
When you post your schematic, make sure that each component has a unique reference designator (R1, R2, etc.) and the component's value. Without this information, discussing how the circuit functions is very difficult.
ak
dl324
Joined Mar 30, 2015
18,476
Not without more information. What is the part number for the relay and where's the schematic?
Your posts would be easier to read (meaning you're more likely to get responses) if you used proper grammar (capitalization, paragraphs, and sentence terminators).
LowQCab
Joined Nov 6, 2012
5,102
Most Relay manufacturers will provide "Must-Break" and "Must-Make" Voltages,
unless, of course, You got your Relay from China.
dl324
Joined Mar 30, 2015
18,476
Of the relays I've used, pick-up voltages of 70-80% of the nominal coil voltage were specified. 70% required selected devices.
You're below 65%.
