Relay chatter/sparking
Macknumber9
Joined Jun 10, 2023
34
Here's a test you can try. Connect a 1K resistor to 12 volts and the other side to the base of the transistor associated with the relay coil and see if the relay activates normally if it does then check the voltage on the collector also.
Use jumpers or hardwire in if necessary.
Do you know roughly the voltage I should see with that set up?
Macknumber9
Joined Jun 10, 2023
34
If it works less than 1 volt on the collector, .6 to .7 volt on the base.
Thanks so much...going to try this...what about the already .5v that I'm getting at the base with it running....I'm going to do this while it's running....is that going to be too much voltage with me adding the .7v?
Macknumber9
Joined Jun 10, 2023
34
While it is running and the already .5 volts on the base will be fine. Just try not to short out anything.
Does the .5v seem low to you? I thought I should get .7v on an npn silicon transistor....maybe mine is Germanic I don't know how to tell
It's gonna be next to impossible to get readings while doing this test though
Macknumber9
Joined Jun 10, 2023
34
Can't you use jumpers to connect the resistor?
Don't know but can you do this:
Well I'm not worried about connecting the 1k resistor...I'm worried about touching to the base of transistor...I need that to be alligator clipped so I can grab my multimer and probe the voltage readings that I am getting on the collector and elsewhere that you told me to get
Macknumber9
Joined Jun 10, 2023
34
Yes .5V seems low but it's not a germanium transistor.
Can you hardwire the resistor in?
Yeah so .5v is definitely my issue like I thought...maybe this test can tell me something....or maybe I just need to desolder the damn transistor already and actually run tests with it off board....I heard the tests don't work with the transistors unless they are desoldered and isolated off the board...this sound right to you?
sghioto
Joined Dec 31, 2017
8,733
That's normally true. Can you see which resistor is connected to the base of said transistor?
Reading voltage on the base resistor is another way of testing.
Macknumber9
Joined Jun 10, 2023
34
Read both ends of the resistor please.
What's the number of the transistor on the pcb? Q6, Q7?
Ok thank you so much for your help...I will have to wait until Tuesday or Wednesday to do these tests but I can't wait to see what results I get....
Q6 is the transistor driving the relay in question
Macknumber9
Joined Jun 10, 2023
34
I final note, I believe the circuit I'm posting is correct for the relay circuit.
Looks good to me...what's strange is the transistor's base is not in the middle....I always thought that the base must be in the middle so the collector and emitter are separated from each other....don't know why my trabsistor is set up with collector in middle...
