Picked up a free wine cooler...diagnosed a bad relay on pcb...I was getting 12vdc on power supply side of coil but only 6vdc on the side driven by the transistor....I was thinking I shouldn't see 6vdc...I'm confused though not sure if when probing ground to coil I should see 12vdc or 0vdc there...anyways I turned off the machine and jumped 12 volts to the supply side and grounded the other side (transistor side) and got the relay to click but did not have continuity on the load contacts....so I figured bad relay....well I was right because I soldered in new relay and it fired up...thought all was well until I heard a terrible rattling sound...checked the relay and it was dark in the room and there's a tiny little slit in the top of the relay...I could see sparks flying in there....is this relay chatter?
Now I was thinking it could possibly be a compressor that is going bad and drawing too much amperage....but that doesn't explain the odd 6vdc on the transistor drive side of the coil....or does it?
Could it be bad compressor? If so how would I test? Just test the amperage coming out of it?
Bad transistor?
Diode?
Possibly the transistor is bad or something is going wrong on the ground side of this coil causing a weak electromagnetic field and not allowing a strong pull on the contacts?
Bad transistor?
Diode?
