Relaxation Oscillator
133Cs
Joined Nov 3, 2019
Hi, I hope this is the right place for asking it. I've come across a relaxation oscillator circuit with an opamp. I've understood how it works and the influence of the various components, but i can't figure out the function of the resistor R4 at the top right. Could you give me some elucidations?? Thanks
JohnInTX
Joined Jun 26, 2012
4,787
Welcome to AAC!
OP1 might be a comparator e.g. LM393 with an open collector output. In that case, R4 acts a the pull-up that allows the output to go high. The pinout looks like a 741 OpAmp though so maybe not.
133Cs
Joined Nov 3, 2019
Welcome to AAC!
It's exactly what i've thought, but it specifies a ua741 opamp. Can such resistance still provide some advantagies in that case?
Alec_t
Joined Sep 17, 2013
15,152
The 741 is not a rail-to-rail output opamp, so the pull-up action of R4 will help to raise the output above what it would otherwise be.
133Cs
Joined Nov 3, 2019
In fact, through a simulation in Tina (Opamp ua741C, dual supply 10V, R1=R2=100k, R1=27k), the output changes steeply for R4 small, until it stabilizes. However I can't figure out why the opamp out can be affected by the resistor. bb.jpg
Alec_t
Joined Sep 17, 2013
15,152
Between the Vcc rail and the output pin of the 741 output stage there are the collector-emitter path of an NPN transistor, plus a series resistor. These drop voltage. The pull-up provides a current bypass to these, reducing the drop.
