Reg Atmega 168
ksp1717
Joined Oct 30, 2008
13
Hi all
I am new to the microcontrollers other than PIC...and also I used to program and use the pic using a target board, icd from CCS kit which is given here .
I want to use the atmega line of microcontrollers now..... I am planning on making my own target board as a trail.
I have seen this simple method of doing it here.... what i want to know is ..
can i make a simple target board as described in tht link and use an
AVR programmer - USB stk500v2
and a suitable computer software to program my atmega. Is it possible to do that or do I need anything else.
hgmjr
Joined Jan 28, 2005
9,027
I don't have any first-hand experience with the device shown in your link but it certainly seems viable. The free software development utility from Atmel called AVRSTUDIO4 should be useable with this device since it is compatible with the STK500 programmer. Make sure that the target board that you are building is provided with a correctly wired ISP6PIN connector.
hgmjr
John Luciani
Joined Apr 3, 2007
475
I would use the AVR ISP MKII as mentioned on the Evil Mad Scientist page.
It is not clear from the description if the programmer can drive devices
at the target systems voltage level. A lot of systems are using 3.3V. It
may be useful to be able to program these devices.
(* jcl *)
