Reflection of a Point Over a Line
zulfi100
Joined Jun 7, 2012
656
I have a figure containing a triangle and a rotated triangle superimposed at the centroid. I have joined two points of the resultant overlapped image created from the original and the rotated triangles. Now I want to do a reflection over this oblique line. I searched the internet but i cant find any equation. Eq. are provided for reflecting over x-axis, y-axis , over the line x=2 & over the line x=y but no equations are shown for reflecting object over an oblique line. One site gave the method to find the eq of line which was used to reflect the triangle but it didnt give any example for reverse case. Its link was:
http://www.rcboe.org/cms/lib010/GA01903614/Centricity/Domain/1030/Reflections.pdf
I have attached the figure. I want to reflect portions of the two triangles over the dark fat line.
Some body please guide me.
Zulfi.
MrAl
Joined Jun 17, 2014
13,870
Simply, it looks like if you were to rotate the dark line and get rid of the offset and used that info to rotate every other point on the graph too, then any point could now be reflected about that dark line by simply calculating the negative of that points y value. If you then rotate that new point back and add the offset back, you get that point rotated about the original line. You could analyze this process and come up with a formula.
zulfi100
Joined Jun 7, 2012
656
Thanks for your response. I have to just reflect only four points and then join them with the end-point of the fat line by drawing lines.
Can you please show this mathematically? Why using rotation for doing reflection? Why not perform the reflection directly? Do you mean rotation about an arbitrary axis?
Zulfi.
35,281
2-D and 3-D graphics take advantage of matrix operations. The basic operations are addition and multiplication on matrices.
Do you know how to do this?
MrAl has laid out the correct procedure.
Translation is accomplished by matrix addition.
Rotation is accomplished by matix multiplication.
Step 1 - Translate (x1r, y1r) to (0,0) by adding (-x1r, -y1r)
Step 2 - Rotate about (0,0)
Step 3 - Form the reflection by multiplying with (1, -1)
Step 4 - Do reverse rotation
Step 5 - Do reverse translation
Tesla23
Joined May 10, 2009
560
I think this is easiest with vectors:
Representing a point P by a vector P from the origin
a line L with unit normal N and passing through a point Po is all points P:
(P - Po).N = 0
where . is the vector dot product
the vector from any point Px to the foot of it's perpendicular to the line L is
(Px - Po).N N
where we have used the fact that N is a unit normal i.e. |N| = 1
so the reflection of Px in the line L is
Px - 2 (Px - Po).N N
zulfi100
Joined Jun 7, 2012
656
Thanks for showing interest in my problem.
Mr. Chips
What would be the angle of rotation?
Mr. Tesla:
(P - Po).N = 0
Sorry I cant understand this. If you have time, kindly transform the symbols P , vector P, line L, P0 and N according to my diagram.
Zulfi.
35,281
Your line is (x1r, y1r) - (x2, y2).
You want to make this line horizontal by rotating about (x1r, y1r) as the origin.
Do you know how to calculate the slope of this line?
Tesla23
Joined May 10, 2009
560
write the line as
a*(x - x0) + b*(y - y0) = 0 with a*a + b*b = 1, then the unit normal is n = ai + bj and Po = (x0, y0) is a point on the line
So for a general point Px = (xp, yp)
write d = (Px - Po).n = (xp - x0)*a + (yp - y0)*b
and so the reflection of Px in the line has coordinates (xp - 2*d*a, yp - 2*d*b)
You should check this, it's possible I've messed up a sign, but the method's sound.
zulfi100
Joined Jun 7, 2012
656
Thanks Mr. Chips:
Slope would be:
m= (y2-y1r)/(x2-x1r)
From one site I got this formula:
Math.atan2(yDiff, xDiff)*180.0/Math.PI;
where atan2 a java function
Thanks. I would try this.
Another link is:
https://www.mathworks.com/matlabcen...ope-of-the-line-connecting-two-rotated-points
but its confusing.
Hi Mr. Tesla
You mean i have to find a point on the line nearest to a given point. I found the formula:
I would try and reply you.
Thanks.
Zulfi.
MrAl
Joined Jun 17, 2014
13,870
You could also try doing it outright using variables x,y, and angle A where A is the original angle of the line.
If you rotate x and y using the rotation equations and angle -A to the point xn,yn, then take the negative of yn as -yn, then rotate xn and -yn by angle A, the result is a pair of convenient double angle formulas that are in the same basic form as the rotation equations themselves except for signs and of course the double angles. These two formulas rotate the point x,y about the line with original angle A.
Of course you'll have to add the offset to this procedure.
35,281
You now have all the steps to do this. Since this is homework, I will leave it up to you to proceed.
Step 1 - Translate (x1r, y1r) to (0,0) by adding (-x1r, -y1r) to the given point (x,y)
Step 2 - Rotate about (0,0). Angle θ = atan(slope)
You now have all the information to do this for a single point. If you wanted to do this for a large collection of points you would do this using matrix arithmetic.
Tesla23
Joined May 10, 2009
560
Hi Mr. Tesla
Thanks.
Zulfi.
No, the reflection of (xp, yp) is (xp - 2*d*a, yp - 2*d*b), you should try to understand the method if you are using it. All you need is the equation of the line and the definition of d = (xp - x0)*a + (yp - y0)*b. (x0, y0) is any point on the line (intercept is fine).
The translation/rotation/reflection method will work as well and use that if you understand it, but this will give the same answer and I think is simpler.
MrAl
Joined Jun 17, 2014
13,870
Hello again,
Here are the two regular rotation equations for a single rotation:
xn:cos(a)*x-sin(a)*y;
yn:sin(a)*x+cos(a)*y;
The point (x,y) is rotated by angle 'a' to the point (xn,yn).
Here are the solutions to the reflected point i found:
X=cos(2*a)*x+sin(2*a)*y-sin(2*a)*b
Y=sin(2*a)*x-cos(2*a)*y+cos(2*a)*b+b
where the point (x,y) is reflected about the line with angle 'a' and y intercept 'b', and (X,Y) is the resulting point.
Note the similarities to the rotation equations, but did i make a mistake perhaps in one of the signs or even the entire result? That's up to you to determine. You should try to prove that result and see if you can or if you can disprove it.
Tesla23
Joined May 10, 2009
560
Of course, if this formula is correct (I'm not saying it isn't, but I haven't checked it), then it will give you the answer as well, as the closest point on the line to the point P is the foot of the perpendicular, call it F. If you have found F then you can find the reflected point directly by going from P to F and going as far again in the same direction. So if P is (x0, y0), and if F (x0 + dx, y0 + dy), then the reflection point R is (x0 + 2*dx, y0 + 2*dy). In other words, as F is the midpoint of P and R, if you know P and F you can find R. This is really the method of the vector solution I've been explaining.
zulfi100
Joined Jun 7, 2012
656
I have tried with first method following the steps laid down by Mr. Chips. I think two points are right & two points are wrong. If somebody interested in debugging my reflection code please let me know. I would check this again and try finding the results using Mr. Tesla23's method.reflection testing.jpg
Zulfi.
zulfi100
Joined Jun 7, 2012
656
I would should show you my JAVA code:
Code:
void reflectionAboutAnAxis(Graphics g){
  //reflecting points (x1, y1), (x2r, y2r), (x3, y3) & (x3r, y3r) about the line
  //having end points (x1r, y1r)-(x2,y2)
  //Step 1 - Translate (x1r, y1r) to (0,0) by adding (-x1r, -y1r) to the given point (x,y)
  Double x1T= x1-x1r;
  Double y1T= y1-y1r;
  Double x2rT= x2r-x1r;
  Double y2rT= y2r-y1r;
  Double x3T = x3-x1r;
  Double y3T = y3-y1r;
  Double x3rT = x3r-x1r;
  Double y3rT = y3r -y1r;
  //Step 2 - Rotate about (0,0). Angle ? = atan(slope)
  Double slope = (y2-y1r)/(x2-x1r);
  Double Angle = Math.atan(slope);
  Double x1Tr = x1T*Math.cos(Angle * Math.PI/180.0) - y1T*Math.sin(Angle * Math.PI/180.0);
  Double y1Tr = x1T*Math.sin(Angle * Math.PI/180.0) + y1T*Math.cos(Angle * Math.PI/180.0);
  Double x2rTr = x2rT*Math.cos(Angle * Math.PI/180.0) - y2rT*Math.sin(Angle * Math.PI/180.0);
  Double y2rTr = x2rT*Math.sin(Angle * Math.PI/180.0) + y2rT*Math.cos(Angle * Math.PI/180.0);
  Double x3Tr =  x3T*Math.cos(Angle * Math.PI/180.0) - y3T*Math.sin(Angle * Math.PI/180.0);
  Double y3Tr =  x3T*Math.sin(Angle * Math.PI/180.0) + y3T*Math.cos(Angle * Math.PI/180.0);
  Double x3rTr = x3rT*Math.cos(Angle * Math.PI/180.0) - y3rT*Math.sin(Angle * Math.PI/180.0);
  Double y3rTr = x3rT*Math.sin(Angle * Math.PI/180.0) + y3rT*Math.cos(Angle * Math.PI/180.0);
  //Step 3 - Form the reflection by multiplying with (1, -1)
  Double x1Tr_ref=x1Tr;
  Double y1Tr_ref=-y1Tr;
  Double x2rTr_ref=x2rTr;
  Double y2rTr_ref=-y2rTr;
  Double x3Tr_ref=x3Tr;
  Double y3Tr_ref=-y3Tr;
  Double x3rTr_ref=x3rTr;
  Double y3rTr_ref=-y3rTr;
  //Step 4 - Do reverse rotation: tried with -Angle also
  Double x1T_ref= x1Tr_ref*Math.cos(Angle * Math.PI/180.0) - y1Tr_ref*Math.sin(Angle * Math.PI/180.0);
  Double y1T_ref= x1Tr_ref*Math.sin(Angle * Math.PI/180.0) + y1Tr_ref*Math.cos(Angle * Math.PI/180.0);
  Double x2rT_ref = x2rTr_ref*Math.cos(Angle * Math.PI/180.0) - y2rTr_ref*Math.sin(Angle * Math.PI/180.0);
  Double y2rT_ref = x2rTr_ref*Math.sin(Angle * Math.PI/180.0) + y2rTr_ref*Math.cos(Angle * Math.PI/180.0);
  Double x3T_ref= x3Tr_ref*Math.cos(Angle * Math.PI/180.0) - y3Tr_ref*Math.sin(Angle * Math.PI/180.0);
  Double y3T_ref= x3Tr_ref*Math.sin(Angle * Math.PI/180.0) + y3Tr_ref*Math.cos(Angle * Math.PI/180.0);
  Double x3rT_ref = x3rTr_ref*Math.cos(Angle * Math.PI/180.0) - y3rTr_ref*Math.sin(Angle * Math.PI/180.0);
  Double y3rT_ref = x3rTr_ref*Math.sin(Angle * Math.PI/180.0) + y3rTr_ref*Math.cos(Angle * Math.PI/180.0);
  //Step 5 - Do reverse translation
  Double x1_ref= x1T_ref + x1r;
  Double y1_ref= y1T_ref + y1r;
  Double x2r_ref = x2rT_ref + x1r;
  Double y2r_ref = y2rT_ref + y1r;
  Double x3_ref= x3T_ref + x1r;
  Double y3_ref= y3T_ref + y1r;
  Double x3r_ref = x3rT_ref +x1r;
  Double y3r_ref = y3rT_ref +y1r;
I checked the input values inside the method & values are correct:
x1=30.0 y1=30.0
x3=75.0 y3=107.94228634059948
x2r=89.14213562373095 y2r=5.50252531694
x3r=112.43584968295782 y3r=92.43584968295781
After reflection, I am getting following output values
ix1_ref=30
iy1_ref=108
ix2r_ref=90
iy2r_ref=131
ix3_ref=74
iy3_ref=29
ix3r_ref=112
iy3r_ref=44
Some body please check what's the problem with this code.
I would try with other method.
Zulfi.
Tesla23
Joined May 10, 2009
560
I was bored and tried this in Geogebra (https://www.geogebra.org/apps/) where you can setup an interactive geometry online.
Try this https://www.geogebra.org/m/GsX6VnEw and move P around.
This was created by going into GeoGebra Math Apps, and entering into the box:
the following (you need to rescale a bit using the mouse wheel and some panning):
P1=(25,69)
P2=(120,30)
L1=Line[P1,P2]
a:=x(L1)
b:=y(L1)
a1=a/sqrt(a*a+b*b)
b1=b/sqrt(a*a+b*b)
P=(80,80)
d:=a1*(x(P)-x(P1)) + b1*(y(P)-y(P1))
R=(x(P)-2*d*a1, y(P)-2*d*b1)
you will get:
and if you click on the point P with the mouse, you can drag it around and see the reflection point behave accordingly. It's really neat. You can even drag P1 and P2, changing the line etc..
35,281
Code:
  Double x1T= x1-x1r;
  Double y1T= y1-y1r;
x1=30.0 y1=30.0
ix1_ref=30
iy1_ref=108
ix2r_ref=90
iy2r_ref=131
ix3_ref=74
iy3_ref=29
ix3r_ref=112
iy3r_ref=44
Zulfi.
I see two mistakes.
The angle to rotate is -atan(slope).
Angles are already in radians.
I am away from a computer. I will show you the easy solution using matricies in two days time.
zulfi100
Joined Jun 7, 2012
656
I have tried again based upon what you said and i got following values:
x1=30 y1=60 x3=75 y3=137 x2r=89 y2r=35 x3r=112 y3r=122
x1_ref=56 y1_ref=123 x3_ref=33 y3_ref=36 x2r_ref=115 y2r_ref=99 x3r_ref=70 y3r_ref=21
and the new diagram is attached.
