Sending the pic for the board.Is this a MC2100 main board?
If so, what is the flash rate of the LED?
Max.
Max.
Hihi again,
the fault you first mentioned (flashing console etc ) is the same fault as mine.. I would have thought the fault lay in the console but from what I can see from you diagnosis is that the fault is in the motor control board instead.. is this correct ?
I had the same issue as you described. because it was out of stock - I decided to research and fix the issue as described above. Please make sure you have a surge protection strip to prevent a repeat.Hi
Yes the fault on mine was the motor control board, l would recommend getting access to the board and getting the part number to ensure any replacement is correct before ordering.
I've found where l got mine from, call this number 0800 440 2459, it's Reeboks parts supplier in Milton Keynes, currently they are out of stock till month end, but the cost including VAT and delivery is £66.49 with manuf warranty.
Hope that helps
