Reduction of Back EMF effect in BLDC motor
ak52
Joined Oct 15, 2014
241
Hello Everyone,
I have a few fundamental doubts on the effects of back emf on a dc motor and was hoping to have them cleared.
Firstly , Let me explain the hardware setup. I have a DC-link capacitor voltage of about 300 V which connects to 3 parallel half bridges and the midpoint of each bridge connects to the motor.
What would be the effect of the back EMF at rated speed of motor on the DC Link voltage?, If the dc link voltage is not regulated, would the net resultant voltage across the dc bus be (dc bus voltage - Vback emf)?
Secondly:
I would like to include some kind of back emf protection in case the motor stops suddenly, the voltage across the DC link capacitor raises sharply,
My first thought is to use a brake chopper to waste the excess energy across it. But in order to do this, (calculate the maximum power that would be needed to be dissipated(hence choosing the appropriate brake resistor values)) , how do i calculate what will be the maximum voltage the dc-bus will raise to incase of a sudden motor stoppage? Can i assume the worst case to be 2x Dclink voltage?
Thanks!
Papabravo
Joined Feb 24, 2006
22,111
Back EMF is a property of the motor and the speed of revolution. There is no practical way to reduce it except to use a different motor or run it at a slower speed.
ak52
Joined Oct 15, 2014
241
Hello Papabravo,
Thanks for your reply, yes I am aware of that, i think my thread title was a misleading (don't know how to change it now),
What i meant was that during a sudden stop of the motor , there would be a steep raise in the dclink voltage due to a sharp raise in the back emf, how do we safely mitigate this ?
Papabravo
Joined Feb 24, 2006
22,111
I guess I would need a schematic diagram of your setup. Since the motors are not directly connected to the DC-Link capacitor, I don't see why this would be a problem.
Ian0
Joined Aug 7, 2020
13,273
What is a DC link capacitor? Show us a schematic.
It’s just the capacitor across the DC supply to the three half-bridges.
The MOSFETs which form the bridges look like a three phase bridge rectifier when they are all switched off, so when the motor acts as a generator it charges the DC link capacitor.
Unless the motor is over speeding, I would not expect its generating voltage to be higher than the DC link voltage.
kubeek
Joined Sep 20, 2005
5,796
The DC link voltage will only increase if either the motor is overspeeding because of some external force, or because your 3f bridge is actively trying to brake the motor. Braking is IIRC done by running the PWM at lower duty cycle than what is appropriate for the motor at the current motor RPM. The half bridge then acts as a step up converter in the direction towards the DC link capacitor, and that is why phase converter IGBT bricks typically have three pairs of transistors for the bridge and one transistor to switch on a braking resistor whicht loads down the DC link and provides a sink for the energy coming from braking.
ak52
Joined Oct 15, 2014
241
Hello Ian and Kubeek, Thanks for the reply, unfortunately I don't have a schematic yet, but Ian described it accurately!
@kubeek, but what happens if we remove the motor load suddenly?, Wont the motor temporarily overshoot?, thereby increasing the back emf?
Ian0
Joined Aug 7, 2020
13,273
If it’s a synchronous motor then why would it over speed when the load is removed? if it’s an induction motor, perhaps it could.
