reduce RTD resistance output from 1000 ohm to 100 ohm
Brad Selmon
Joined Feb 8, 2016
I have some 1000 ohm Resistance Temperature Devices.
My input board only accepts 100 ohm RTDs.
Is there a passive component that could "step down" that signal ?
OBW0549
Joined Mar 2, 2015
3,565
I guess you could put 111 ohm precise low tempco resistor in parallel.
The problem with that approach is that the parallel combination has only 1/10th the sensitivity of an actual 100Ω RTD. Instead of the normal 3850 ppm/°C it would have only 385 ppm/°C.
Designing signal conditioning circuits for RTDs is already a non-trivial task for all but the most crude, non-demanding applications. Reducing the RTD's sensitivity tenfold would make achieving any useful level of accuracy and stability a MAJOR challenge.
