Reduce power consumption on SD card
tapasXplore
Joined Apr 2, 2012
I am using micro SD card to log data from sensor. It logs data every 15 minutes and then goes to sleep. I am using MSP430G2553 uc from TI, using 1000 mAh battery, still battery is not lasting for a week. While the uc sleeps, micro SD card continuously consumes power. Is is possible to reduce power consumption drastically, without changing schematic. Schematic and code is attached below.
Regards,
bertus
Joined Apr 5, 2008
22,999
The posted image does not show as it is linked to a local PC.
When you want to show an image over here, please upload the image using the "Upload a File" button below the reply window.
Bertus
