Red LED's Running Lights Using 4017 and 555 Astable Timer With Variable Resistance 0-1KΩ
Dalila Damia
Joined Oct 18, 2016
9
Is the switch spst and push button important in this circuit? I do this project without putting them in the circuit but it's not working.
Dalila Damia
Joined Oct 18, 2016
9
When open the toggle switch only removes power from the 555 circuit.
The reset button will cause +9v to appear on Q6 output when closed.
What part of the circuit isn't functioning correctly ?
Is the 555 generating a output is disconnected from the 4017 input ?
All the led does not lights up.
Dalila Damia
Joined Oct 18, 2016
9
I draw the circuit using livewire and then i convert it to PCB. So this is the picture. Maybe it will help.
IMG-20161212-WA0017.jpg realworldIMG-20161212-WA0018.jpgartwork
Reloadron
Joined Jan 15, 2015
7,948
The 4017BP is configured as a Count To N and Recycle and in this case N is the Q6 output so when Q6 sequentially goes High it applies a Logic High to Pin 15 Reset and the count repeats again. The Reset Push Button allows for a manual reset at any time in the cycle. The SPST toggle switch powers the 555 clock pulse generator, it could be replaced with a straight wire bypassing it, If you have a scope you need to look at the output of the 555 chip. Pin 3 should be a pulse string out to the 4017 Clock Input. Check your pins and wiring as it should work.Pin 13 of the 4017 is a clock enable pin and should be held low to enable the clock i signal.
Ron
Dalila Damia
Joined Oct 18, 2016
9
Is the 555 generating an output ?
Output voltage at 555 only 1.4v
Is the reset pin being held low ?
Is pin 13, the clock inhibit pin (not clock 2 as shown) being held low ?
Are the LEDs the correct way round ?
All LEDs are connected correctly
Is the 4017 showing any signs of overheating ?
Yes
You said you omitted the two switches, what have you done in their place ?
I replace it with a straight wire bypassing it
Dalila Damia
Joined Oct 18, 2016
9
If you have replaced the reset push button with a piece of 2 things are happening.
1: The 4017 is being held in a state of reset
2: Output Q6 is being connected directly to 9v
I suspect you may have damaged your 4017. Connecting the reset button and output Q6 both to the reset input is a design flaw.
A datasheet for the 4017 maybe of help.
I have cut off connection between pin15 & pin16, and solder a wire at pin16 as a reset button like in the pic. Is it okay?P_20161214_002618.jpg
