Recycled LEDs
Status
Not open for further replies.
mapleman555
Joined Dec 15, 2014
56
OK. While I'm at it I have related question about LEDs. I used my handy electronic component tester(http://www.ebay.com/itm/Atmega328-T...657?pt=LH_DefaultDomain_0&hash=item19f77ba7e1) on the LED I lit up last night expecting it to say it couldn't identify what the LED was but to my surprise the tester said it was a diode. Then I was on line looking at the new flat (don't even look like a bulb http://www.carid.com/diamond/g-4-si...n-52626.html?gclid=CIePkKCausMCFZJm7Aod7HQAmw) LEDs and it said the were diodes, is that what they are?
bwilliams60
Joined Nov 18, 2012
1,450
Yes and no. Yes, the current driven through an LED varies with voltage. The problem is that the voltage range between <turn-on, very dim>, and <out-of-spec, exploding bright> is only about 1/2 volt. Worse, this range will vary from LED to LED, and will even vary with temperature for a particular LED.
In this narrow range, the current rises roughly linearly with voltage, from <1mA to 20mA typically. So if you have a precision voltage source, you can use it to vary the brightness of an LED. But it's much easier and more reliable to control the current over the 0-20mA range. You won't have a problem switching from on LED to another, and temperature variation won't matter.
Thank you for the clarification. I appreciate it.
Status
