- Joined Jan 23, 2018
- 27,637
The problem may indeed be high voltage spikes that arc from the rotor to the field coils. In some motor applications with some kinds of non-conductive load, such as a belt, somehow a static charge builds up on the rotor. The solution is a rotor grounding device that keeps the rotor connected to the motor frame. The problem is common enough that products to do this are available. And who would ever guess that was the source of the high voltage?Thanks you.
I can relate to what u are saying because at a point we used a higher rated vfd (“5.5 kW”both Omron and Toshiba) to run the motors separately (each motor 0.5 kW) and they operated quite fine for a long while.
Eventually we lost their IGBTs along the line. The problem still persisted.
I’d really appreciate it if u could help me get the application note u are talking about. I believe it can help.
