Rectangular battery shaped Piece.
LesJones
Joined Jan 8, 2017
4,543
It looks like part of the foot operated speed control for a sowing machine. I think there may be pieces of carbon inside the ceramic part that are pressed together when pressure is applied. I think the metal parts act as a switch to short out the carbon pile to provide full speed.
Les.
Freeman Dom
Joined Dec 2, 2021
44
Les.
Yes there is 2 pieces inside, as shown here.
LesJones
Joined Jan 8, 2017
4,543
If you measure the resistance between the terminals when you press on the screw that goes through the item from the opposite end to the contacts you should find that the resistance reading reduces as the pressure is increased.
This is a link to a video to give you an idea pf how it works.
Les.
Freeman Dom
Joined Dec 2, 2021
44
Les.
Exactly.
Thank you so much LesJones for your help and for the video.
